06 choke / idle
Discussion in 'Sportster Models' started by DZRyder, Jun 19, 2009.
  1. DZRyder
    DZRyder Member
    53
    And again i look for enlightenment here on HDT. At start up i pull the choke out and it will not stay out, not a big problem, but it used to have to be pushed in after a few minutes. Is there an adjustment? Also, after engine is warmed up good when i stop at lights the idle is high, i listen to other bikes and you hear the potato idle. Should i adjust the idle cable and could this be connected to the choke problem?:33:
  2. kemo
    kemo R.I.P
    1,690
    5
    There is a plastic nut behind the choke knob bracket. Tighten it gently to adjust tension on the cable. You may have a vac leak causing your high idle. Spray some either around the back of the intake. If you notice a difference in the idle you have found your problem
  3. glider
    The answers are in the self help forum. :D
    Enricher Knob Tension - Harley Davidson Community
  4. glider
    Much better choices than either. Due to it's extreme flammability, all you need is a source of ignition and the rest is history.
  5. DZRyder
    DZRyder Member
    53
    Not real sure what you mean? Behind the air cleaner back plate? Where might the leak be coming from. I noticed a tube coming down thru the frame between the cylinders that had been melted and a small hole is visible?
  6. cowjammer
    cowjammer Active Member
    148
    I'd be starting there.Sounds like you've just found your problem. Wouldnt you have to worry about the white thread getting sucked in ? I was always told to use water in a squirt bottle, But I cant say weather its good advice or not. GOOD Luck and let us Know.
