The only difference between a 2006 96" and 2006 88 is the crank. The 96 has a 4 3/8" stroke where the 88 has a 4" stroke. The barrels and pistons are the same. When you put the big bore on you end up with the 103? So I would say they should be fine. Anyone else???
The crank has the rods moved farther to the outside which gives it more stroke. So the distance the piston moves in the bore is 3/8 " farther (higher) on the 96 cu in engine. You use diff pistons for the stroker cranks as well . The diameter of the pistons is the same though. Hope I explained that well. Sorry for confusion.
