03 Ultra starter relay number
Discussion in 'Electrical' started by DresserDan, Sep 12, 2012.
  1. DresserDan
    DresserDan Member
    36
    Anyone know what the auto parts store number is for 03 Ultra starter relay?
  2. Rubyred
    Rubyred Senior Member
    1,020
    12
  3. DresserDan
    DresserDan Member
    36
    I want a auto parts store part number.Would save me a 100 mi trip or wait 5 days. Most of the parts people dont know how to find anything if it isnt listed on the computer.If I have a number it would make it easier.I can remeber seeing guys in parts places that would know exactly what you had or could find it real quick.Not any more.It has to be on the screen.
  4. Rubyred
    1,020
    12
    Try here, they have starters with part numbers.
    [​IMG]
    RareElectrical
    [​IMG]
    [​IMG]
  5. tourbox
    tourbox Senior Member
    1,885
    168
    I usually tell them I want a 5 pin fan or horn relay.They just take me to Isle where they are hanging and I get the one I want. Don't know a part #.
    tourbox
  6. Jack Klarich
    Relay - Starter | AutoZone.com you could start here
  7. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    I think a 12v relay is a 12v relay as long as the pin # ( pin # means each pin has a number by it, ie, 80/85/86/30) and pattern is the same.
    Auto parts horn relays are about $6, worth a try.
  8. DresserDan
    DresserDan Member
    36
    Harley says it has a diode and is 15 amp.I am just trying to make it easy so I dont have to tell the parts guy where to go.Most of these auto parts guys dont know dit and if they cant look up what it fits they have no idea what to do.I have had guys that you could show them the part and they still cant find you a part.Relays are really bad trying to find one without knowing what it fits.
  9. Hoople
    Hoople Account Removed
    7,198
    34
    Not trying to confuse the issue but,
    Go to the J&P catalog link below. Enter page 250. (Actual page in catalog shown will be 248) At the bottom of the page you will see item 380-777.
    It says Starter relay with diode.
    The diode is the key. Whatever relay you choose to use is fine as long as it has the diode. Most relays don't come with a diode. The diode is needed to clamp the PIV voltage that is generate by the relay itself when the relay releases. Since this relay is activated (or picked) by the TSSM (which is a solid state device) it is important to have the internal diode.
    A diode is not needed on pre-ECM/TSSM bikes.
    J Catalog
  10. DresserDan
    DresserDan Member
    36
    Is there any way to tell if a relay has a diode by looking at it?
