03 Softtail cutting out
Discussion in 'Softail Models' started by nmfatboy, Feb 27, 2011.
  1. nmfatboy
    nmfatboy Member
    10
    I have a 2003 Fatboy FI. Occasionally, I will be cruising at around 50-60 mph and the bike just cuts out. Electrically. Its like the bike turns off. It always starts right up after I kick it in neutral, but its irritating. Anyone else had this problem? Fixes?
  2. dbmg
    dbmg Guest
    Do you have anymore specific info. What type of mods on bike, was a check engine light on at any time, what was the last service or upgrade done and how long has this been going on?????
  3. nmfatboy
    nmfatboy Member
    10
    No ck engine light. Has not happened for few months. Only mod is upgraded exhaust.
  4. Hoople
    Hoople Account Removed
    7,198
    34
    irritating and Dangerous. As dbmg said, need more info unless you want a list a mile long on things it could be.
    If it starts back up, a current check engine light will not be on. But a possibly a historical code could be set. You have to hand check it.
  5. Dave Kincaid
    Dave Kincaid New Member
    4
    My '01 did this and it turned out to be a combination of the main circut breaker, then eventually a new ECM (Electronic Control Module), to the tune of over $500.00.
  6. nmfatboy
    nmfatboy Member
    10
    Ouch! Hope I can get it resolved for less than that
  7. NEWHD74FAN
    8,191
    98
    19
    When you say it cuts out electrically, are you saying all the lights go out (not even the turn signals function, including the dash lights? Is your bike equipped with Security Alarm system? Have you checked for Diagnostic Trouble Codes? Have you checked the inlet corrogated fuel line hoses in the tank? Sometimes "dead" is not truly...:s
  8. gator508
    gator508 Well-Known Member
    2,754
    179
    My sportster had similar symptoms once, took it to the dealer under warranty and they said the positve battery cable was loose, they tightened it up, never happened again.
  9. moto mundo
    moto mundo Member
    53
    check the positive and negative connections to the battery and frame. and if your bike have a 40 amp. circuit braker change it for a 50 amp.
  10. Hoople
    7,198
    34
    ...?. Why
