02 Road King Code 14
Discussion in 'Touring Models' started by Bubbat450, May 25, 2009.
  1. Bubbat450
    Bubbat450 Member
    18
    I have been having an on going problem with my 02 harley idling too high (1150rmp) I have replaced all of the intake and fuel injection seals and O rings, I have cleaned the stepper valve. I have replaced the cam chain tensenors. (Boy they where close to GONE!!) 46K
    I have a PC
    Big sucker air filter
    Fullsac Exhuast
    I had this problem before that stuff.
    I read the codes and it was a 14
    HELP!
    50
    The code 14 is an engine temp sensor problem located on the rear of the front cylinder. It may be telling the ECM that the engine is still cold and that's why the high idle. Check the wiring and if no problem is found replace the sensor.
  3. Bubbat450
    Bubbat450 Member
    18
    Thanks!!! Maybe this is it!!
    I checked the plug and what wire I can get to. Should I check it all the way back to the ECM plug?
  4. STEVE07
    4,128
    68
    86
