I had a pulse in the front brakes. One or both of the OEM solid rotors is warped. Decided to upgrade the solids to floating rotors. I was hoping that I could replace all three rotors, but the rear screws are larger diameter than the fronts. So the same floating rotor will not work for all three.
Also replaced the brake pads and the rubber isolator in the rear wheel driven pulley.
Parts:
http://s731.photobucket.com/user/TQuentin1/slideshow/Upgrade OEM Solid Rotors to Floating Rotors
Cheers,
Parts:
- Chrome Floating Brake Rotor-44944-08A
- Original Equipment Rear Brake Pads-41852-08B
- Original Equipment Front Brake Pads-41854-08
- ISOLATOR, RUBBER - 40278-09
Cheers,
